You can download and use version 20.6.2 from the downloads page. That version doesn’t need anything extra to work with your display.
Jogging the machine in continuous mode requires the key to be held down to move. Hold the key down to move, release the key to stop. Is that what is happening?
When i hold down any arrow in 300 ipm continuous mode it moves 1 inch and stops until i let the arrow key go and tap it again. Keep in mind it is in continuous mode. I move the ipm to 200 or any other speed it moves with the arrow keys just fine
A much clearer explanation. I can’t explain why it would do that. Try downloading 20.6.2 and use that. It was a very stable version of the Firecontrol program and I am still using it.
Going to try a different dxf file from langmuir site and see if it will work correct. Using a sharpie. Plasma cutter off with breaker off. I woll post picture after it finishes
Was in process of setting up and a guy pointed it out to me that my plamsa cutter wasnt compatable. So it took me a couple weeks to buy a different one
