How do you create toolpath from the Solidedge 2D ? Do you transfer it to sheetcam and it will create the toolpath ?
You can create a Flattened SVG and use that to go into SheetCam. You can also create a DXF, but then you need to export the correct version and I don’t remember which one works. And even then, there are artifacts that need cleaning up.
