I created a sign with both letters and lines. I need lead ins for the letters, but not the lines. See pic:
Any suggestions?
Any suggestions?
Do two different cut paths with the letters in one and the lines in the other.
For the lines set sideways compensation to center and click off leadin and lead out and set your pierce clearance to zero.
Beautiful!! Just what I needed.
I just tried it and I am good to go. Didn’t know you could have more than one cut path.
Thanks!!
Yup you can make as many as you want just make sure you have setup highlighted when you make the gcode so it gets them all and not just the one you have highlighted.
