SheetCam programming isses
I am new to sheetcam and having some issues with posting a program. I was able to get a simple “C” cut earlier today so I decided to go with some with some more detail. I keep getting this error when I generate my code and save the program. Any ideas will help. Thanks in advance.
Looks like possibly, you have just the trial version installed… This trial is only good for a few lines of simple code… When switching to the more complex drawing, it looks like you’ve exceeded the 180 line limit… OR… You have the licence installed in the wrong directory…
If you purchase the license for SheetCAM you should get a set of instructions that spells out how and where to install the file…
Hope this helps!!
That sounds like it would be it since the program that ran was a small program. I did purchase it, so I will check where my files are. I appreciate the help!
If you purchased it they would have sent you an email with instruction to activate it.
Yup they did. I now remember not downloading the license when they sent it. Thanks for the help everyone. It is much appreciated. Now…Let there be sparks!
