I’m wondering if anybody is or has seen this error code in sheetcam it won’t let it do the post process if i want to do the cutting in two operations. Thanks
Post processing…
Part:Star 4
Inside Offset, Color 1000000, T1: Mild Steel 26 ga. 30 amps 40 psi 0.0591 in kerf Prime Weld Cut 60
Outside Offset, Color 1000000, T1: Mild Steel 26 ga. 30 amps 40 psi 0.0591 in kerf Prime Weld Cut 60
Error: Evaluation limit reached
Post processing failed
Sounds like the Posts you’re trying to generate end up creating too many lines of Gcode for the evaluation version of Sheetcam… I forget what the limit is but, something like 300 lines sticks in my head. Someone will chime in with what the exact number is…
You’d have to simplify your drawings or possibly make it into multiple index’d cuts??
I’ll bet you wouldn’t regret buying Sheetcam… IMHO…TOTALLY worth the $140.00 !!!
When i order the license for sheet cam will i have to start all over installing tools and project files or do i have to just install the license .
Thanks
just install the license.
if you want you can actually save your tool file, which is always a good idea if you make changes…for back-up reasons.
Sheetcam will just unlock the features with the license…
