Setting up my work shop
Maximum Electrical out put ?
What size air compressor?
These are essential for maximum out put for my crossfire pro!
Thank you!
These should be in the the operating manual
These parameters relate to your Plasma Cutter, not the table. The table itself probably doesn’t draw more than 350W.
Like above said, your electrical draw is whatever your manual says for your plasma cutter, air flow is the same. Langmuir can’t list this individually in the table manual, it all depends on what plasma cutter you are using. If your plasma cutter requires 8 cfm you will want 12 or so cfm to be sure you have enough on a long cut and you do not get pressure drop.
