I’m having an issue where I designed an item, everything cuts except the 4 circles in the design. I select them during the contour selection, can select if it’s cutting on the inside or outside. Everything looks good, but during the simulation tab, it doesn’t seem to recognize the contours I selected. Any tips?
If the lead ins and lead outs and other linking constraints won’t fit inside of the hole it will be excluded.You can try to reduce the lengths of these until it puts a toolpath to them or increase the size if the hole.
