Hi,
In Mach3 you can scale x and y separately. This allows you to have (for example) a generic 10 x 10 square cut file and manipulate that into not only
Squares but also rectangles (ie 0.9x, 1.1y) etc. Similarly a generic circle could be used to make ovals by adjusting the two dimensions separately.
It looks like fire control does not have this option and instead scaling is uniform in all directions. Is this correct or am I missing additional functionality somewhere? If it is missing might be a useful addition to put back in the next release.
I’m thinking particularly for those who want to be able to quickly cut the widest range of shapes with the minimum amount of computing.
