Anyone know why Resume doesn’t work after you pause your cuts? Mine just faults out and says to retry the path??
When are you pausing the program? It won’t restart cutting if you pause it in the middle of a cut. It will only restart If you pause between cuts.
Well that would make sense. Yes I am in between the middle of a cut. I suppose it would resume if I turned on the torch and then hit resume??
You will have to use “start from line” and select the line that you hit pause on. It will regenerate the code starting from that line. In the future if you need to pause do it between cuts.
I hope that answers your question.
You absolutely answered it!! Thank you for the help
