Was making a sign and it cut everything perfectly until I started running the border cut and it cut half way around and stopped cutting but the head kept moving. Is there anyway to back it up to where it stopped cutting and run from there?
Click on the spot on the screen where you want to start. In the box that shows the code, you will see a message that says run from line or loop. Choose run from line. It will load a new program that starts from that point forward.
