How are you guys who have water tables reducing warping?
I don’t really have problems with warping
keep water level high in table
so…to reduce warping you 1st really need to tune in your settings…
too hot and too slow build up heat and will cause warping…
next keep the water high…splash does help keep metal cooler.
the other thing I do is keep a small spray bottle hanging on the water pan…just spray water on the areas behind the cut path…it helps
Add a pause after each cut and spread the cuts out to lower thermal distortion.
