Razorweld pressure change
My plasma cam it set at 60 pounds. trying to get cover off so I can turn the regulator up. Any instructiopns? thanks
I thought the internal regulator was set for 80psi.
It’s not hard to take the cover off - all the screws are pretty visible except maybe the two on the top on either end, they may be under a bit of the plastic from the front. You will need to free the top handle and spread the front & back apart a bit so you can free the side casing.
Oh, make sure you leave it unpowered for an hour before you start digging inside. There are capacitors in there that can take a bit of time to drain and you don’t want to get zapped.
