Correct. It’s based on whether you’re cutting inside or outside the line. That’s what the blue arrows in Fusion mean when you select an object or line for a toolpath.
If you look at the swirl ring in your torch when you change consumables you can see the tiny holes that the air comes out of. They’re actually angled and you can see that if you look inside the ring. That’s what causes the swirl.
