Razorweld 45 Air Pressure issues
I can make a cut, but when the machine moves to make a second cut it will not cut. I ran a THC test and when I fire the torch the gauge on the front of the cutter bottomed out, then there is a delay, & then I hear a click and the gauge goes back to normal.
Thc has nothing to do with torch firing. What the air gauge bottomed out? if so, do you have sufficient air supply to machine? and have you adjusted air regulator to the torch?
I have a video posted on the Facebook page. I can’t post the video from my phone. I have ample air supply.
You have a air restriction or blockage some were cutting your air flow. The gauge should never drop mare the 5 to 7 psi .
I don’t do fakebook.
