Hi All
Still trying to get the unit up and running. I am having trouble with the scale translating to the table
I have a 24x24 table
I have downloaded the DLL and pasted into mach3/plugins
When run the table from 1 corner to the opposite it believes the table is 160 x 160
Is there something fundamental (likely) that I am missing. appreciate any ideas
Yes, you need the CrossFire Config file. You’ll find that in the downloads area. This is a text file that you put into your Mach3 top level folder and then, when you start up Mach3, you need to specify that as your configuration.
thanks, I certainly missed this file and have it now. When you say “Specificity that as your configuration” any insight on how I accomplish that? if there is a video or something I should reference just let me know. Thanks for the help, much appreciated
