I’m an avid CNC hobbyist / woodworker that wants to do metal work. The Crossfire looks like a great shop addition, but I’m wondering about all the other stuff that goes along with use…
I would clear out a corner in my garage for the plasma table, but does it make a monster mess with the water table and sparks to where you constantly have to clean?
Also, what type of air control are you running when cutting? Would a fan blowing above the table and out the garage door be sufficient in vapor control, or did you install an air handler above the machine of some sort.
Will my garage and woodworking equipment get covered in fine metal dust?
Is drywall and inside of garage door going to hold up to the mess that shoots off the machine or will I need some corrugated steel siding wrapped around the table area?
Thanks in advance for any info you can provide. Looks like fun so I’d like to make it all work without spending a small fortune.
