Need advise ON How to connect Powermax 65 to
Crossfire Pro.
Power supply to Crossfire electrical box is 110 volts
While Power Max 65 runs ON 220 volts what do I need to do?
Is IT okay to connect them using different v0ltages?
They don’t share that current. That’s what the voltage divider is for which connects to the cpc port of the cutter (if you have one). Control box is meant to plug into a standard plug, while the cutter goes in the 240 volt plug.
