@langmuir-daniel Is the plastic isolator in assembly step #14 a standard item? Is it necessary to have if it wasn’t included?
Hi Eric,
No it is not necessary. We cut the change into production to do away with the grommets that get installed into the enclosure. If you have the grommets in your box, you dont need the plastic isolator.
Perfect! Thanks, Man… I appreciate all of your crews hard work.
