Plasma Cutter Suggestion for finest details?
Hello!
New to Plasma CNC. I’m trying to spec out a system. Could anyone suggest a cutter that can achieve the finest cuts? Speed is not an issue. What ever would get the cleanest detail. We will be cutting 3/16" cold Rolled Steel. and some Aluminum.
If not a suggestion, any specs I should be looking at when shopping for a plasma cutter.
Thank you.
Randy
You may get a bunch of opinions but I think the newest Hypertherm 45 series with “fine” tip is the best out there.they don’t say how large “fine” is and they don’t call their tips “tips” because of their magic design but it does seem to make the finest cuts.
I have the 45xp…if you get it go straight to the fine cut consumables…You wont be disappointed.
