Plasma cutter shelf
I’d like to create a shelf on the pro but above the table on the side or back. My table sits out in the floor so no walls handy. Post any pictures if you’ve done it…
This fellow looks like he created a very nice one on Fireshare. https://www.langmuirsystems.com/fireshare/rmf-razorrack
That’s a nice find. It’s looks good. But for someone without the big base cabinet, I’d test the idea first by seeing what 40lbs of cutter will do perched up on the end of the frame - best case is that it will lighten the other side so it’s likely to dance more when cutting…worse case might be a tipover :slight_smile: You’ve got a fairly high momentum of mass up that high and that far from the machine’s COG.
My God! Is that a mattress on that table!!!??? Now THAT is dedicated to your work!
