I’m running a pro with a razor weld 45 thc , using fusion as my cam ! Here’s the issue my torch goes down touches off material raises to one inch , fires drives down to pierce height .then takes off to run program , I have pierce height set at .080 , there’s something I am missing ???
Welcome to the forum.
Do a small test design, create the GCode file and cut and paste the text here. That usually provides a clue.
After you’ve posted a few times you’ll be able to do file uploads.
(v1.6-af)
G90 G94
G17
G20
H0
(2D Profile1)
G0 X1.4235 Y1.3515
G92 Z0.
G38.2 Z-5. F100.
G38.4 Z0.5 F20.
G92 Z0.
G92 Z0.
G0 Z0.8 (Pierce Height)
M3
G4 P1.
G0 Z0.063 (Cut Height)
H1
G1 X1.253 Y1.253 F70.
G2 X-1.253 I-1.253 J0. F70.
G2 X1.253 I1.253 J0.
G1 X1.4235 Y1.1546
H0
M5
G0 Z1.
M30
(PS70)
Your pierce height is set at .8". It should be .08" if you want that as a pierce height.
Somewhat unrelated, your springback and backlash is probably excessive at .04"
Thank you don’t know how I missed that I will edit it on fusion , and give it a try , thanks , as for spring back I have never ask it what would be good ball park to start at ?
Backlash accounts for backlash in the lead screw. My testing showed that there was basically no backlash in a relatively new assembly. Springback accounts for the metal flexing when the Torch presses on it. 1/8" and up usually doesn’t flex from the Torch pressing on it.
For anything 1/8 and up, I would set that at zero. You can pause during a cut and measure the actual torch height.
