when in the machine post window and i put in mach3 for processer the window does not display the bottom buttons ok and post any help would be great
Welcome to the forum!
Since this was more of a question than an introduction, I moved it to the software/mach3 section to get more appropriate eyes looking at it.
Do you have an older machine that runs on Mach 3? The tables produced in the last couple of years run on Firecontrol.
I’m assuming your referring the post window in Fusion 360? If so, I’ve also had a similar problem that the default window location is too low on the screen. Try dragging the post window higher on the screen.
If not, kindly disregard…
Might be more Software/Fusion360 CAM question?
Yeah, I think you’re right. I keyed in on Mach3 and didn’t register that he was talking about post.
