My machine was cutting great, then I changed my consumables out(which I acquired from langmuir) , now all I get is a pilot arc???my plasma cutter is less than a yr old. It has less than 5 hrs on it. I tried to contact langmuir about swapping out my torch. But can’t find any contact info for em
Do you have the torch holder too tight?
If you are getting a pilot arc, then the work clamp (some times referred to as a ground) is not making good contact with the metal.
No I’ve got a good ground. When you pull the trigger, it fires for about half a second, then goes out.
Is air turned on?
Air pressure must be at least 65 psi with air flowing from the torch. You could have a bad electrode, the electrode sticking in the swirl ring, the electrode plunger sticking, etc. I would remove all the consumables push the air set switch and blow out the torch, then replace all the consumables with new ones and see what happens.
The air is good. Clean and dry at 90 psi. I broke my torch head down to see what is going on. And when I assemble my torch with new consumables, as I’m screwing the retaining cap down, I noticed what I guess is the plunger, the rod that comes out the back side, it pushes out about .100-.125". Is it supposed to come out that far? Please help me someone.
65/70 psi on the gauge of the plasma cutter with air flowing from the torch. You should never take your torch apart. Pictures of the consumables may help.
I will be at the shop 8/12 till 5pm if you want to call me. I will try and help you get this taken care of.
George
302-690-6995
