Need help combining images
I am trying to make this all one piece. But cant figure it out on fusion 360. Any help would be appreciated.
Modify then combine?
I tried that. It tells me to click on which body I wanna combine, but I cant click on anything.
are you using the text tool on fusion?
Yes I am using the text tool.
Right click on text, “Explode text”, and then highlight and fix.
This is what I got done so far. But still cant figure out how to delete some of the lines.
Looking good, use hotkey “T” to trim each line.
uou have to clock on edit sketch first
on the left side you see sketch 1 select it >right clock > edit sketch
than youll be able to trim the lines
I got it!!! Thank you everyone for helping. Greatly appreciate it.
Finally got to cut it out. Turned out great, just gotta clean it up and paint it.
Nice job. I like the style. With large steel signs you might want to go with thicker/wider fonts just from a proportionality perspective but this one is a pretty clean & clear design. It’s all aesthetics from now on :slightly_smiling_face:
