Why do I keep getting NC failed? Fusion 360
What are you trying to do?
I designed brackets put everything in. Sent to g code, saved it. Went to open it file said nc.failed like 3 times
Have you cut anything before or is this the first
Been cutting for about 2 months. Was going great . Then today this. So I loaded other stuff I cut and works fine. Ended up redesigned it and worked
Hello! I had this happen once and it was bc I forgot to change in the settings from in control to in computer. Just a thought!
Funny you said that checked that too. I’m wondering if my computer is having issues too. Possibly to slow. The second time I put it all back in it worked
UM? Well that lets me out! Sorry I can’t help!
I’ll take any suggestions. Thanks
that is why I call it…conFusion360…
I’m still confused is it not generating a cut path and fusion is your issue or is it generating a cut path and your problem is in fire control with your saved file?
