My table wont finish a gcode and fire control needs to be restarted
From your description this sounds like interference from the plasma cutter. Read this thread:
For tips, basically make sure you have the USB chokes installed.
Does this happen if you perform a manual torch fire? have a piece of scrap under the torch and be ready to turn off the plasma cutter if it stays stuck on.
