Metal will not cut
My design will not cut all the way through. Not sure if it is a problem with my tool on fusion or my machine. The metal is 3/8 inch thick. Let me know if anyone knows why this is happening. Thanks.
You will need to tell us more if you want help.
Do your home work and list everything you can about your set up and your cutting settings EVERYTHING you can think of
We’ll have to get your settings to know more or you could post your G-Code. But I can speculate a little bit with the limited information.
Work clamp not on the material
Bad or improper consumables
Wrong amperage setting.
Too fast for amperage setting.
Incorrect cut height.
We should be able to whittle down this list once we have a few more pieces of the puzzle.
Hard to tell for sure, but it looks like your pierce cuts went all the way through, so maybe just slow the cut rate.
@kur here are some basic questions to give us a little more context.
System Info
What Type of CNC table do you own?
Do you have a Z axis for THC?
Are you Connected to Raw or Divided Voltage?
Are you using Nominal Voltage or Smart Voltage for the THC?
What Type of Plasma Cutter do you have?
What torch are you using on your Plasma Cutter?
What consumable stack is install in the torch?
What is the current Consumable Condition ?
What is the specs of your compressor?
How are you drying the compressed air?
Are you placing the work (ground…) clamp directly on the material (work)?
Are you using a Laptop , Mini PC or Desktop?
Which operating systems are you using?
Are you using Firecontrol or Mach 3 ?
Which version of Fire Control are you using?
Are you using SheetCAM or Fusion 360 for post processing?
Operation Info
What material type are you cutting?
What material thickness are you cutting?
What consumable stack are you using for this cut?
How fast are you cutting in IPM(inches per minute)?
What is your cut height?
What is your pierce height?
What amperage is your plasma cutter set for?
Are you set to Smart or Nominal Voltage?
If a Nominal voltage what are you setting it to?
How many inches of cutting are in this program?
How many pierces are in this program?
Can you post the G code *.tap or *.nc ?
Can you post a design file *f3d or *f3z from Fusion 360?
you forgot to ask his eye color…hehehehehehe
