My father has installed fusion and mach3 his laptop. We keep running in to an issue where Mach3 opens and it has changed its default home screen to a Mill setup rather than the standard plasma. The only way I have been able to fix this to uninstall mach3. Delete the mach3 folder from the C drive and then reinstall it.
I hope there is an easier/ quicker fix to get around this issue in the future if it happens again.
Yes. He is selecting the Mach3 loader icon and the crossfire profile. I have deleted all other profiles and the 2 other shortcuts that Mach3 installs to be safe.
Sadly I could never resolve what caused it. I had to uninstall Mach3 and delete all supporting files and then reload. (Knock on wood) this hasnât happened since. I reached out to Mach3 support and never heard back. Best of luck.
Itâs not too hard to accidentally âtouchâ the Mach 3 configuration and, if you do, it will prompt you to save the change. If you do save, it will overwrite the working configuration.
Seems downloading just the Crossfire configuration should restore it, however. Unless youâve changed it and not saved it elsewhereâŚ
