My G code looks fine, and simulates well in fusion360, but I get into mach3 and the toolpath generated is missing massive chunks. Can anyone help out?
1001.tap (19.3 KB)did you buy the full license for it? if not then you are only limited to 500 lines of code and if your file have over that then mach3 will only show up to 500.
That was the problem! Thank you
