I have two Crossfire tables with separate laptops running them. The one runs just fine. The other computer Mach 3 will open up, I can load my G Code into it, hit the reset button and it doesn’t jog. The X Y show that its moving, but it actually isn’t. Any ideas? Thanks!
What happens when you swap laptops?
Then no issues. So it has to be in the Mach 3 software. I looked through the configs but didn’t see anything obvious.
Does that mean the problem follows the laptop? If that is the case, the simplest thing might be re-installing Mach 3 (after a full uninstall) on the broken machine.
Any answers on this issue, I’m having same issue’s with mine
