Hello Newbie here,
setting up new pro machine lost my jog function was working, also ran break program i get screen on laptop to move but machine will not move. Sorry not the best on computers.
Thanks
Stupid question. Is the power to the control box on? Did it blow a fuse? The screen will work regardless of the box being powered on.
Welcome to the forum!
I’m surprised that @Bigdaddy2166 didn’t ask you if you have Limit Switches installed. He attributes ALL failures on this equipment to their existence.
Power switch on I can hit limit switch by hand and see them working on screen, is there a fuse in the control box?
Take off the cover on the control box and make sure the power supply is in the 120v position. It a switch on the side of the actual power supply. It may be in 220 v position. While you are in there check to make sure it’s putting out 36 volts DC .Adobe Acrobat
Turn off the limit switches on Fire control and see if it works.
