Anyone here use the Leadin type options?
Ramp would replace the pierce delay I assume?
And wiggle just wiggles the torch around during pierce?
Any benefit experienced in terms of consumable life?
i believe both of those are for when cutting pretty thick material to make the pierce easier and cleaner. not sure what you’re trying to cut so not sure if you’d see any benefits. I dont think any would really effect consumable life, unless youre doing really thick stuff
Ah, makes sense. Max I do is 6mm so probably no benefit then. Just got curious looking through the settings.
I tried perpendicular based on something I read in Plasma Spider and it sure made my holes nicer on 14 gauge. I also messed with the start point in sheet cam, I could not be happier about the results.
