Leadin orientation
I’m using SheetCam. My lead in’s are opposite of what I need. ie, lead in starts outside inner circles and inside the perimeter of the part. I’m sure it’s an easy fix but I’m not seeing where to reverse that. Help.
In your Jet Cutting operation, select “Outside Offset” and it will assign the correct offsets to the inside and outside offset contours.
Thank you. That did it. It changed my tool comp also but with the parts I’m making, that makes no difference. Really appreciate it.
I’m not sure what you mean by “tool comp”, but I think that is a Fusion term. If you mean the cut direction, you should have the box for “reverse cut direction” checked in the Jet Cutting operation window. That will make it cut the proper direction for plasma cutting.
