Layers in fusion How to edit them? (solved)
I downloaded a artsy piece and when I open it in fusion it show as a layer not a sketch.
I do not see any way to edit the layer.
I did notice the DXF shows as a DWG maybe that’s the problem?
unicorn.dxf (299.7 KB)
I ‘open’ vector files using “Insert” into a new or existing Sketch. From there you can modify it and, after closing, extrude it.
Will give that a try and report back, thank you Sir!
That did it thank you!
