so totally off off the range topics here…something I thought I should let people know about…
Laptop issue
so I had my laptop Lenovo (Thinkbook 15 G2 ARE) blank out on me yesterday…I was in the middle of changing metal on the table…had just cleaned up the dropout of a previous cut and put the magnetic pencil down…
turned around and the laptop was blank…wiggle mouse…tap keyboard…power on and off…nothing.
then I piocked it up…screen came on…put it back down…screen went off…
I found that I had put the telescopic pencil magnet down beside the laptop…with the magnetic end pointed and resting against a port…no idea what the port is…remove the pencil magnet…screeen on…put it back screen off…real strange.
so if you ever loose the secreen on a laptop…look for magnetic interferance.
Material clamp
this one is a liitle bit more on the explainable side.
was tired after cutting yesterday…left the material clamp attached to a small piece of metal on the table…the wire attached to the clamp was in the table fluid…the cable ran down the table to the floor and over to my plasma cutter…
this morning I got up and saw a puddle of fluid under the plasma cutter…not good when the rest of the floor was dry…and not good to mix plasma cutter with unexplained fluid…
turns out the table fluid traveled not down the outside of the cable…but on the inside of the cable…
I now have the cable hanging from the ceiling watching fluid drip out of it…
gonna open plasma machine to check for water…
very strange morning…
