Kerf setting in Fusion 360 for 1.1mm nozzle
Yep. The edges of holes get that. Sometimes makes it harder to later ream or drill out to final size.
There should be. But I haven’t done it. I started using the peck method after I switched to Sheetcam. I would think a similar drill operation could be defined in F360. There are a bunch of posts here about using the technique.
@TomWS is the expert in the technique.
