Its worknig OK But having minor issues
I am using a Thermodynamics Cutmaster 52. It will not start the first cut unless I pull the trigger on the torch. Or if I initaite the cut a second time. But the air needs to be coming out the end. It will almost always start and stop on a complicated multi piece job.
Today after cutting multiple pieces it tried to start the cut about an inch off the plate. I restarted on a fresh piece and it worked fine.
Can you pick where you want to resume your cutting when this happens.
Welcome to the forums.
Check out this link on the 60i goes through a few of the issues people have to overcome.
