Issue with visualizer - Solved by Uninstall/Re-Install of Firecontrol [SOLVED]
Any time I open up my file to cut the visualizer isn’t on, it’s turned on in the settings and it’s not popping up for old codes either which worked perfectly fine in the past.
If you search for this topic on the forum, you will find this pop up at least every 2 weeks for the last 3 months. In most cases, people have been able to resolve by doing a complete uninstall, including deleting the folder where it lived on your computer and then installing the more “stable” version that is designed for slower graphic cards.
If you go to the support page on the Langmuir website, look for “Downloads” you will find the files available.
Often times this will bring back the visualizer function. Sometimes it does not. Those that have had the function return, some find that they can then update from that point and still maintain the visualizer function.
It is hard to tell what happened with many who have had this problem because there are more than a few times, that once someone’s issue is resolved they do not report back to the topic to tell us what happened and what was the actual solution. It is like the adage of finding something: It is in the last place you looked. “The solution will always be the last thing you did before it started to work again.”
Good luck. Report back.
Search the forum for the outcomes of others: remember “less is more” meaning that when you search, use less words so you will find more results by just using the word “visualizer” and not “issue with visualizer.”
I did as you asked, and it fixed my issue entirely, I assume it was just a corrupted file issue due to my graphic driver being more than enough to run FC
