IHS Height Too High
I made many cuts yesterday, with zero issues. It appears upon starting Fire Control this morning, there may have been an update?
My IHS is now piercing and trying to cut way too high. Its running around 1/2 an inch or more above the metal. It goes down to the metal and “senses” like I would expect, but just upon firing the torch, it goes up a little more than 1/2 and inch to 3/4 of an inch and fires the torch, then after the pierce attempt, continues to travel at that height.
I have adjusted the machine settings in F360 and tried manually overriding in Fire Control, with no luck. Any suggestions?
Post the first 20 lines of your GCode file (it’s plain text so you can cut & paste if that’s easier for you). This will isolate an ‘instructed’ move from ‘sick hardware’.
sounds like you entered .6 for a cut height, not .06
For those replying, he entered a springback value of 0.22 and a pierce height of 0.09
Repeat issue of something similar 4 days ago
