I need help with fusion 360!
I keep getting “Failed to generate tool path”
                    warning 1 is " Z axis has 1  missing  selection"
                    warning 2 is " model has 1 missing  selection"
lets add one more to the books , when I generate a tool path and transfer it over to the mach 3 for some reason it only transfers part of the image , but fusion 360 simulates all of the cutting?
Are you using the trial version of Mach 3? It only works with 500 lines of code, and these have many more lines than I expected.
You may want to look at your setup again. There may be some elements you’re cutting out that are not set in the ‘model’ in your setup. I’d guess thats where the issue with your z axis is too.
When you simulate the cut path in Fusion, is the whole path cut out? If so then it maybe be the mach limit as freetocut mentioned.
I did purchase the full Mach 3 version and as I look in the top left it says Mach 3 demo , could that be the problem ?
It may be if fusion is generating a path for the whole part. If you purchased the full version Mach3 from us, check your email from back in July where we sent out codes and instructions. Heres a link to the tutorial video once you’ve got the code.
I purchased the full version and have never received any email with codes or anything
