Hypertherm 65 THC wiring (no CPC using hand torch)
Wiring in Hyperthem 65 without cpc raw arc voltage for THC.
Didn’t think to get more pictures it only took 10 mins to wire in using a couple ring terminals and existing screws on the board.
Once you pull the cover off pull the plastic shield off covering the board and at the bottom front of the board is where the connections are.
I found the provided wires for the vim box to be to short to run the way I wanted to run them so I just drilled a hole in the front bottom right and put a strain connector there instead of running to the back of the machine like I wanted.
Also the trigger wires for the torch are the standard hypertherm orange and violet wires.
