I have a base model hypertherm 45xp, I will be getting it cnc ready. Does anyone here know if both CPC machine interface port and serial interface board are needed? Part numbers: 428653-CPC and 428654-serial interface
Also which version of fusion 360 do I download? Thanks in advance
If you’re going to get the machine torch just need to get the cpc port then you can fire the torch and get divided arc voltage from the cpc.
If you’re intending on using the hand torch you can just wire the torch fire either inside the torch handle or inside the case and get raw arc voltage from the board inside then no cpc port necessary.
