I am waiting patiently for my Crossfire, but I was interested in knowing how many PC Workstations I can install Fusion 360 on? I bought the Full License and I was hoping to install it on my Office PC and also on my laptop that I would connect to my crossfire. Is this possible or do I have to buy another software License?
You can install Fusion 360 on any number of machines. You log into your Autodesk account to sync up projects from different machines. You should only need a paid license if you make more than $100,000 per year from F360 work.
Mach 3 is similar in that you can install it on multiple machines. The license file you get needs to be installed on whatever machine(s) you want to run it on. That one you do need the $175 license in order to run any sizeable project (itās limited to 500 lines of G-code).
jamesdhatch, Thank you very much for your time and incredible insight. I appreciate this very much as I am completely new to this and didnāt want to ask a ādumbā question right off the bat.
Thank you, again. You made my day!
Wade
We all started from zero once.
I have the advantage of spending a few years doing 3D printing, CNC (wood & metal) and lasers. I also teach CNC operations for a local Makerspace so I see some questions pop up a lot - easy to answer those
Thank you, Blakebahruth! I appreciate that info!
Wade
Itās not really āsharedā. Only the initial registrant will get any support. The others will get a question āwhere did you get thisā and then potentially discover it no longer works as the original registrant is told it was a violation of his license term to sell it to multiple people and itās being deactivated.
Itās not illegal for you to buy, nor is it illegal to sell it once but you donāt know what the seller has done before (or after) they sold it to you.
Okā¦I didnāt catch that at the beginning. Definitely I wouldnāt want to be sharing my license or someone elseās. Thanks for the clarification on this point, Jamesdhatch.
Yea I didnāt even think of that
