I have been trying to get my cut quality figured out and it’s been extremely frustrating. I can’t seem to get my internal cuts to make clean cuts. No matter what I do I still have little divots and only on my inside cuts.
Any suggestions on lead in/lead out?
Here are my settings in depth
Is your kerf really .025". I suspect it’s a bit wider than that and your lead in of .055 is probably not enough to keep the pierce hole from crossing over the cut line.
I would increase the lead in to at least .100" and reduce the overlap to about .060"
This is what i do for fusion guessing something similar for sheet Cam. My guess is your selecting all not inner and outer individually if that makes sense for cut path.
Your actual kerf width is probably closer to .050"
Make sure you select “outside offset” in your jet cutting operation. That ensures that Sheetcam will assign the correct offsets to inside and outside cuts.
