Anybody who has a Langmuir could you share some pictures are what you think about it. I’m thinking about getting one but would like your think about it. A video are two would be great. I’m from Ohio and would like to see one but looks like no one has one around here. Thanks
Look around the forum here. There are lots of people posting pictures, reviews, videos, etc…
youtube has a few and this Forum has plenty. just take a little time to look and read.
What part of Ohio? I’m from the Athens area.
What Part of Ohio? I’m in the Akron/Canton area.
Coldwater, Ohio look me up at Starlight Drive-In on facebook
Coldwater, Ohio. Would like to see one in action.
Between Dayton and Lima would like seeone working. Thanks
I’m quite a bit more east. I’m prolly 3 hours from you. McArthur Ohio.
Just BUY IT! You won’t regret
Would like to come and see it. Dan
I have one in my victory …should be up
cutting tomorrow
If I buy the table and plasma cutter will that be all I need to start cutting projects
You’ll need a PC to control it. If you have one you can bring to the machine then you’re set there otherwise you may want to get something you can use in the garage . If you design on another PC then the garage one can be pretty low-end as it only has to be able to run Mach 3.
You can cut without a water table but make sure you’re doing it far away from flammables as you’ll get a fair amount of sparks flying.
You’ll need some kind of PC to do the design and tool path/G-code generation. If you have something already you may not need a new one (try running Fusion 360 on it).
Once you get it (maybe even before) you’ll want to get replacement consumables - tips, nozzles, shield, etc as you’ll wear those out and having them handy means not waiting to get more. They’re pretty inexpensive.
You’ll need a compressor and an air dryer/dessicant. The dryer and some connectors is probably $25 at Home Depot .
Are there different tips for cutting fine cuts
That would all depend on the plasma cutter and torch you have.
