Hello all! New to the forum. 24 years as a certified ( 2 states, NC & VA ) Water / Wastewater professional, 10 years now as a hobby fabricator, welder, machinist. Not new to CNC plasma tables, just sold my 2’x4’ CNC plasma table by Premier Plasma on 9/9 and turned right around and ordered the CrossFire Pro on 9/10. Been using the Everlast 80S plasma cutter, LOVE it, with a machine torch. Just waiting on the delivery of the CrossFire Pro!
Welcome into the fold… What part of Virginia are you in?
Out in Culpeper
Lots of great knowledge here. I am down in the southwest part close to TN KY line.
Yeah, been skimming thru the forum and can see the knowledge. Already know that I want to do the water pan drain mod. Starting to look like I might have to machine a dimple die myself.
The drain is a very crude setup works though. I don’t do the dimple I just welded a piece of pipe to a piece of 1/8 ss then welded to the pan crude as well but fast and effective. I would also consider welding the pan some have no trouble others do.
Highly recommend welding the pan. Should be a breeze if you have any TIG experience.
You welders are Hot Stuff!
Thank you thank you. I usually get called a cold turd.
Thought about welding mine once I get the pans but also highly considering running a strip of Dicor butyl Tape in between the two and bolt them together. Will decide once I get the pans and what kind of mood I’m in (TIG welding mood or Dicor Butyl tape mood)…lol
Welcome! I’m currently in NC\VA. I’m in Loudoun now so you aren’t too far from me.
now there is a profession that will fit right in with this crowd!!!..
welcome to the forum!
Welcome to the group!! Originally from Martinsville Virginia but niw in Texas.
quick look at pic…SRV
Yeah i worked for the Town of Leesburg for almost 2 years, worse Gov. Identity i have worked for in my 24 years of working for Gov.
I used to consider getting a premier before i got my og crossfire.Why did you decide to change?
A few small reasons, mostly nick pick things. Ultimately i wanted something a little bigger, mine was a 2’x4’ with actual cutting dimensions of 23"x47". So, im actually gaining 10" in the Y axis and 1" in the X. I wasn’t willing to pay out another $1,000 to make my table a 4’x4’. Just time for something new. It was a good table, had flaws and i still say over priced. Mine was roughly $5,700 almost 3 years ago when i bought it.
Welcome. I have been using the forum for about 8 months. Great info. FYI on the drain holes. I cut both holes out and installed two stainless kitchen drains. I also put in a small pump with a plumbed fluid basin. I have on valve that I close to fill and open when want to drain. Literally can drain the table in about 2 minutes or less. If you need more information on how I build the system just let me know…
got the same here…
Thats the direction i want to go. Any imformation on your setup that you want to share will be greatly appreciated!
