Newbie here so be gentle. My first cut after some sizing issues and I oriented it wrong so I cut the top off, but any idea what the weird half circle cuts are? Sure it’s something stupid. Thanks for all the help
Off the top of my head and I may be completely wrong…looks like you start and finish points have large lead in and out parameters.
And reversed, inside/outside cuts.
I’m assuming you’re using SheetCam? You should have made the inside cuts, using “Inside Offset”. The lead in and outs are on the outside and they should be on the inside.
Thank you so much I figured it as something silly… thank you
