Judt though id pass this along to anyone who may be experiencing random hard limit errors. While installing the limit switch kit I kept getting random hard limit errors while checking travel and on a dry run if a part. After some checking i noticed my x axis motor connection was a little loose. After tightening i ran the same checks again with no issues. If your having issues, check your motor connections it could be causing it.
Thanks for the heads up!
