Same results every time have tried slow speed and speeding it up with no success still cuts in between going to next cut
Do you have a 2T and 4T switch? If so switch it.
where would I look for that
On your plasma cutter. Usually on the front panel
going to check right now using the razor weld 45 amp
Ok hope thats it.
In the manual. front lay out #4.
Man I have pulled out wat to many gray hairs for a flip of the switch thanks for all the help and quick response
Your welcome. Im just glad it was a flip of the switch .
