I’ve been working for almost 3 weeks to understand why Firecontrol will not open on my laptop. I’m running the latest version as well as the Java I was sent my Langmuir. All I get are the splash screen and then a shutdown.
I was sent a test program to run in Command mode and the results of this are here:
Microsoft Windows [Version 10.0.21390.2025]
(c) Microsoft Corporation. All rights reserved.
*C:\WINDOWS\system32>cd*
C:>cd firecontrol
C:\FireControl>firecontrol.bat
‘firecontrol.bat’ is not recognized as an internal or external command,
operable program or batch file.
C:\FireControl>cd bin
C:\FireControl\bin>firecontrol.bat
Exception in Application init method
java.lang.reflect.InvocationTargetException
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)*
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:78)*
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)*
at java.base/java.lang.reflect.Method.invoke(Method.java:567)*
at javafx.graphics/com.sun.javafx.application.LauncherImpl.launchApplicationWithArgs(LauncherImpl.java:464)*
at javafx.graphics/com.sun.javafx.application.LauncherImpl.launchApplication(LauncherImpl.java:363)*
at java.base/sun.launcher.LauncherHelper$FXHelper.main(LauncherHelper.java:1071)*
Caused by: java.lang.RuntimeException: Exception in Application init method
at javafx.graphics/com.sun.javafx.application.LauncherImpl.launchApplication1(LauncherImpl.java:895)*
at javafx.graphics/com.sun.javafx.application.LauncherImpl.lambda$launchApplication$2(LauncherImpl.java:195)*
at java.base/java.lang.Thread.run(Thread.java:831)*
Caused by: com.google.common.util.concurrent.UncheckedExecutionException: java.lang.IllegalStateException: Unable to load cache item
at com.google.common.cache.LocalCache$Segment.get(LocalCache.java:2051)*
at com.google.common.cache.LocalCache.get(LocalCache.java:3953)*
at com.google.common.cache.LocalCache.getOrLoad(LocalCache.java:3976)*
at com.google.common.cache.LocalCache$LocalLoadingCache.get(LocalCache.java:4960)*
at com.google.common.cache.LocalCache$LocalLoadingCache.getUnchecked(LocalCache.java:4966)*
at com.google.inject.internal.FailableCache.get(FailableCache.java:54)*
at com.google.inject.internal.ConstructorInjectorStore.get(ConstructorInjectorStore.java:49)*
at com.google.inject.internal.ConstructorBindingImpl.initialize(ConstructorBindingImpl.java:155)*
at com.google.inject.internal.InjectorImpl.initializeBinding(InjectorImpl.java:592)*
at com.google.inject.internal.AbstractBindingProcessor$Processor.initializeBinding(AbstractBindingProcessor.java:173)*
at com.google.inject.internal.AbstractBindingProcessor$Processor.lambda$scheduleInitialization$0(AbstractBindingProcessor.java:160)*
at com.google.inject.internal.ProcessedBindingData.initializeBindings(ProcessedBindingData.java:49)*
at com.google.inject.internal.InternalInjectorCreator.initializeStatically(InternalInjectorCreator.java:124)*
at com.google.inject.internal.InternalInjectorCreator.build(InternalInjectorCreator.java:108)*
at com.google.inject.Guice.createInjector(Guice.java:87)*
at com.google.inject.Guice.createInjector(Guice.java:69)*
at de.saxsys.mvvmfx.guice.MvvmfxGuiceApplication.init(MvvmfxGuiceApplication.java:72)*
at javafx.graphics/com.sun.javafx.application.LauncherImpl.launchApplication1(LauncherImpl.java:824)*
... 2 more*
Caused by: java.lang.IllegalStateException: Unable to load cache item
at com.google.inject.internal.cglib.core.internal.$LoadingCache.createEntry(LoadingCache.java:79)*
at com.google.inject.internal.cglib.core.internal.$LoadingCache.get(LoadingCache.java:34)*
at com.google.inject.internal.cglib.core.$AbstractClassGenerator$ClassLoaderData.get(AbstractClassGenerator.java:119)*
at com.google.inject.internal.cglib.core.$AbstractClassGenerator.create(AbstractClassGenerator.java:294)*
at com.google.inject.internal.cglib.reflect.$FastClass$Generator.create(FastClass.java:65)*
at com.google.inject.internal.BytecodeGen.newFastClassForMember(BytecodeGen.java:258)*
at com.google.inject.internal.BytecodeGen.newFastClassForMember(BytecodeGen.java:207)*
at com.google.inject.internal.DefaultConstructionProxyFactory.create(DefaultConstructionProxyFactory.java:49)*
at com.google.inject.internal.ProxyFactory.create(ProxyFactory.java:156)*
at com.google.inject.internal.ConstructorInjectorStore.createConstructor(ConstructorInjectorStore.java:94)*
at com.google.inject.internal.ConstructorInjectorStore.access$000(ConstructorInjectorStore.java:30)*
at com.google.inject.internal.ConstructorInjectorStore$1.create(ConstructorInjectorStore.java:38)*
at com.google.inject.internal.ConstructorInjectorStore$1.create(ConstructorInjectorStore.java:34)*
at com.google.inject.internal.FailableCache$1.load(FailableCache.java:43)*
at com.google.common.cache.LocalCache$LoadingValueReference.loadFuture(LocalCache.java:3529)*
at com.google.common.cache.LocalCache$Segment.loadSync(LocalCache.java:2278)*
at com.google.common.cache.LocalCache$Segment.lockedGetOrLoad(LocalCache.java:2155)*
at com.google.common.cache.LocalCache$Segment.get(LocalCache.java:2045)*
... 19 more*
Caused by: java.lang.ExceptionInInitializerError
at com.google.inject.internal.cglib.core.$DuplicatesPredicate.evaluate(DuplicatesPredicate.java:104)*
at com.google.inject.internal.cglib.core.$CollectionUtils.filter(CollectionUtils.java:52)*
at com.google.inject.internal.cglib.reflect.$FastClassEmitter.<init>(FastClassEmitter.java:69)*
at com.google.inject.internal.cglib.reflect.$FastClass$Generator.generateClass(FastClass.java:77)*
at com.google.inject.internal.cglib.core.$DefaultGeneratorStrategy.generate(DefaultGeneratorStrategy.java:25)*
at com.google.inject.internal.cglib.core.$AbstractClassGenerator.generate(AbstractClassGenerator.java:332)*
at com.google.inject.internal.cglib.core.$AbstractClassGenerator$ClassLoaderData$3.apply(AbstractClassGenerator.java:96)*
at com.google.inject.internal.cglib.core.$AbstractClassGenerator$ClassLoaderData$3.apply(AbstractClassGenerator.java:94)*
at com.google.inject.internal.cglib.core.internal.$LoadingCache$2.call(LoadingCache.java:54)*
at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)*
at com.google.inject.internal.cglib.core.internal.$LoadingCache.createEntry(LoadingCache.java:61)*
... 36 more*
Caused by: com.google.inject.internal.cglib.core.$CodeGenerationException: java.lang.reflect.InaccessibleObjectException–>Unable to make protected final java.lang.Class java.lang.ClassLoader.defineClass(java.lang.String,byte[],int,int,java.security.ProtectionDomain) throws java.lang.ClassFormatError accessible: module java.base does not “opens java.lang” to unnamed module @37851fee
at com.google.inject.internal.cglib.core.$ReflectUtils.defineClass(ReflectUtils.java:464)*
at com.google.inject.internal.cglib.core.$AbstractClassGenerator.generate(AbstractClassGenerator.java:339)*
at com.google.inject.internal.cglib.core.$KeyFactory$Generator.create(KeyFactory.java:221)*
at com.google.inject.internal.cglib.core.$KeyFactory.create(KeyFactory.java:174)*
at com.google.inject.internal.cglib.core.$KeyFactory.create(KeyFactory.java:157)*
at com.google.inject.internal.cglib.core.$KeyFactory.create(KeyFactory.java:149)*
at com.google.inject.internal.cglib.core.$KeyFactory.create(KeyFactory.java:145)*
at com.google.inject.internal.cglib.core.$MethodWrapper.<clinit>(MethodWrapper.java:23)*
... 47 more*
Caused by: java.lang.reflect.InaccessibleObjectException: Unable to make protected final java.lang.Class java.lang.ClassLoader.defineClass(java.lang.String,byte[],int,int,java.security.ProtectionDomain) throws java.lang.ClassFormatError accessible: module java.base does not “opens java.lang” to unnamed module @37851fee
at java.base/java.lang.reflect.AccessibleObject.checkCanSetAccessible(AccessibleObject.java:357)*
at java.base/java.lang.reflect.AccessibleObject.checkCanSetAccessible(AccessibleObject.java:297)*
at java.base/java.lang.reflect.Method.checkCanSetAccessible(Method.java:199)*
at java.base/java.lang.reflect.Method.setAccessible(Method.java:193)*
at com.google.inject.internal.cglib.core.$ReflectUtils$1.run(ReflectUtils.java:61)*
at java.base/java.security.AccessController.doPrivileged(AccessController.java:554)*
at com.google.inject.internal.cglib.core.$ReflectUtils.<clinit>(ReflectUtils.java:52)*
at com.google.inject.internal.cglib.reflect.$FastClassEmitter.<init>(FastClassEmitter.java:67)*
... 44 more*
Exception running application com.langmuir.cnc.desktop.FireControl
C:\FireControl\bin>
I see few issues about this posted online and cannot figure what on my new Dell XPS would be causing this. I’ve taken off all security programs thinking that might help, but the result is always the same.
Thoughts…solutions…help?
